b_smiff Posted February 2, 2009 Report Posted February 2, 2009 Ok, I hav 130 amp alt. I hav a kicker 2500.1. today i put a second yellow top in the back and installed a 200.2 for highs. Now there's a hummin noise that gets higher when i accelerate..wtf is that? and how do i get rid of it? ANNDD I need help findin a HO alt for a 2001 explorer SPORT, 4.0. Preciate any feedback HU: JVC Arsenal AR880 Subs: (4) Incriminator Audio Warden 15s Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80 Electrical: -DB Electrical 275 amp Ohio Gen -BIG III -(5) XS Power d3100s 152.3 In Street Beat 5. State record in Alabama. (USACI) http://www.youtube.com/Itgetslow
b_smiff Posted February 2, 2009 Author Report Posted February 2, 2009 A little update, I jus ran a new RCA cable opposite the side of the truck( a different side of the power wire).. I kno now that it's engine wine, but how do i get rid of it now? What else is there to do? :censored: :censored: HU: JVC Arsenal AR880 Subs: (4) Incriminator Audio Warden 15s Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80 Electrical: -DB Electrical 275 amp Ohio Gen -BIG III -(5) XS Power d3100s 152.3 In Street Beat 5. State record in Alabama. (USACI) http://www.youtube.com/Itgetslow
trainman0978 Posted February 2, 2009 Report Posted February 2, 2009 check your ground wire. Did you use a eye terminal on the end of the wire, did you go to bare metal..... Are your RCA cables crossing any sort of power wire, touching any power wire? touching any factory wiring , even some small wire...? 2007 Toyota FJ Cruiser Voo Doo Blue my upgrades and "build" thread. My Kulicki Box Build -Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars -Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash ) -JL Audio 2 way Component set XR650CSi - Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box. -Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio -All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0, -270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum- -2 Powermaster D680 Powercells in back FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz. Shoehorn, BFH, forklift,duct tape and some zip ties
b_smiff Posted February 2, 2009 Author Report Posted February 2, 2009 Nah, the RCAs clear of power wires, but my ground for both amps is the negative from the battery in the back.. HU: JVC Arsenal AR880 Subs: (4) Incriminator Audio Warden 15s Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80 Electrical: -DB Electrical 275 amp Ohio Gen -BIG III -(5) XS Power d3100s 152.3 In Street Beat 5. State record in Alabama. (USACI) http://www.youtube.com/Itgetslow
dmanson Posted February 2, 2009 Report Posted February 2, 2009 i'd redo the grounds ............ try grounding the amps separately. good luck 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
