I have a regular cab Toyota, and want something pretty loud in it. I want to spend ~2000 total, aside from a headunit. I am no fan of any company in particular but I dont want to run JL or similar. I want to run "independant" companies I guess you would call it. I know that stereo integrity is coming out with a shallow mount BM sub..but I don't know if I want to do something like that or run a console setup. What I was thinking about doing was to run a console, and then port it behind each seat. A couple 12's or a few 10's.
For amps, I don't have a clue, I guess sundown is at the top right now but I don't know who else I would look at for amps. If I run 2 12's I want 2 amps. If I run 3 10's I want one, or two that can be stacked.
I plan on buying/having built a 200 amp alt, and a couple batteries.
What's everyone think?
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
look at RE Sl subs if you decide to look at slimlines, they looked pretty impressive to me for a slimline woofer.
If your going to use a conventional woofer DC's lineup has a little somethign for everyones needs from SQ up to retardedly loud.
I'd look at the DAT 2500.1 if you want about 3krms and the Dat 1000.1 if your looing for somethign smaller that is still capable for amps.
As for batteries i like Powermasters but kinetik has nothign wrong with it as well.
Blowthrough with 4 15's B):D Thats just my suggestion lol, you might be able to fit 4 shallow mount 12's back there idk toyota center consoles are awefully tiny too
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
had no idea RE had a flat sub out. hm.
my only concern is output. i really want to be pretty loud. i know its dumb to say, but something like mid 40's would be perfect and i know you cant just throw things together and say it will be in the mid 40's.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
cant do the blow thru, full custom frame with a crossmember right behind the cab. i really need the truck back to see what i can do. maybe i can do 4 real nice 8's in the console. i loved my RE8's and they were fairly loud. I just don't want to be any less output wise than my previous setups.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
Multiple SL's should put you were you want to be no problem, run 3-4 of them on some power and youll be plenty loud for a daily single cab
the SL's run about 250 right? I wish those BM's would come out. 150 a pop...
guess not. google tells me v1 was 280. RE is good too LOL
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
if output is your consern id steer away form SI products , they are more focused toward SQ now then output
alright then. i guess i just need to figure out what kind of room i truly have. i bought buckets for the toyota so i could have a console and all but i may have to run slim subs. damn. maybe i can get a couple 10s in it without being uncomfortable.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
