subs and amp wiring... (ohm load)
hey,
alright i have a clarion 1000.1 mono block amp, it has an automatic switch internally to change from a 4 ohm load to a 2 ohm load...
when i wire my SVC 4ohm subs in parralel, the amp cuts out alot earlier then it should, however if i wire them in series (8ohm  load) then it works, and the subs are loud...
so my question is, should i be running my subs at a 8 ohm load with the amp running at 4ohms... or should i just run it in parraell(2ohm) and just have my subs noty as loud as possible....
i think the switch for the load has been swtch so many times it is either stuck in 4 ohms, or just doesnt know the difference... can anyone help me???
take that amp back to the store of call up a clarion tech
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ok i got it fixed, i dont know how or why, but this time when i hooked it up in parralell it doesnt cut out until its oober turned up...so yea i think i got it figured out...i got vereything at 2 ohms... so far so good, and my new box sounds LOUD!!!(for 2 clarion tens that is...)
  • Who's Online   1 Member, 0 Anonymous, 1904 Guests (See full list)
