c0smo kram3r Posted February 5, 2009 Report Share Posted February 5, 2009 (edited) I would honestly run a nother cable back up to the negative. I've read ALOT of times people have higher voltage. That picture is wrong. it should look like [1st BATTERY +]--{FUSE}-------------------{FUSE}--[+ 2nd BATTERY] Edited February 5, 2009 by c0smo kram3r Quote Link to comment Share on other sites More sharing options...
takenotes101 Posted February 5, 2009 Author Report Share Posted February 5, 2009 like that? im ganna have about 2200 rms on it Quote Link to comment Share on other sites More sharing options...
takenotes101 Posted February 5, 2009 Author Report Share Posted February 5, 2009 would i need to do the big 3 with 2200 rms? Quote Link to comment Share on other sites More sharing options...
mbaty1 Posted February 5, 2009 Report Share Posted February 5, 2009 would i need to do the big 3 with 2200 rms? Doing the Big-3 will ensure that you are passing as much amprage as possible from the alternator to your batteries in an effecient manner. It ALWAYS helps your car, no matter if you have a system or not, or whether that is a 500 wat system or 5,000 watt system, I would do the big-3 on most any vehicle...... Also, your last diagram was ALMOST right.... forgot the one fuse from the 2nd battery positive to the amp.... total of 3 fuses will be needed in total. Quote Link to comment Share on other sites More sharing options...
takenotes101 Posted February 6, 2009 Author Report Share Posted February 6, 2009 (edited) what battery should i use Edited February 6, 2009 by takenotes101 Quote Link to comment Share on other sites More sharing options...
c0smo kram3r Posted February 6, 2009 Report Share Posted February 6, 2009 how many watts should i use? for what? Quote Link to comment Share on other sites More sharing options...
takenotes101 Posted February 6, 2009 Author Report Share Posted February 6, 2009 for what? the batt that will go in my trunk... like how many amps Quote Link to comment Share on other sites More sharing options...
wierdguy75 Posted February 6, 2009 Report Share Posted February 6, 2009 Battery's aren't really rated by amps enless your talking about cca, its the voltage, alot of people like kinetic battery's. go to kinetic.com and check it out. If you dont wanna put out that much money then i suggest optima red or yellow tops. Find out what best fits your needs. Quote Link to comment Share on other sites More sharing options...
takenotes101 Posted February 6, 2009 Author Report Share Posted February 6, 2009 Battery's aren't really rated by amps enless your talking about cca, its the voltage, alot of people like kinetic battery's. go to kinetic.com and check it out. If you dont wanna put out that much money then i suggest optima red or yellow tops. Find out what best fits your needs. how about this: http://www.sonicelectronix.com/item_7324_Kinetik+HC+600.html Quote Link to comment Share on other sites More sharing options...
c0smo kram3r Posted February 6, 2009 Report Share Posted February 6, 2009 (edited) how about this: http://www.sonicelectronix.com/item_7324_Kinetik+HC+600.html How can we make a suggestion w/o knowing what amp(s) you plan to use? If you plan on running 2200RMS, you need to run the HC 2400 probably especially if you don't have an upgraded alt or you don't do the big 3. That little battery will not get you by. Edited February 6, 2009 by c0smo kram3r Quote Link to comment Share on other sites More sharing options...
