Mr. 973808 Posted February 4, 2007 Report Posted February 4, 2007 Does anybody have any box displacement formulas for ported boxes and sealed box if any are supplied for sealed boxes? THE GRADUATE 10:18:2007
Pokey Posted February 4, 2007 Report Posted February 4, 2007 This was posted earlier too by Alpine....Thanks to David for explaining it all. (legend) L= length W= width H= hieght *= multiply /= division or divide by -= minus ok here is how you figure this out. now just to make sure you get this correct. make sure you adjust the measurements for the wood thickness, I Always take off 1.5 inches off my measuremeants ( I use .75 thick MDF) L * W * H = your answer your answer / by 1728 = your answer in cubic feet. port area W * H = cubic inches of port area ( or port opening) The length of the port will give you your tunning but before we can get that far we need to deduct the displacement of the subz so you would do this. your answer in cubic feet - your sub displacement = you internal air space before port displacement. ok now you know your internal cubic feet with subz in now open WINISD Pro. I dont use the exact subz most of the time because usually they arent in the Database, I find one thats close o it in specs and go from there. If you have never used WINISD pro your not gonna have alot of fun trying to figure it out, I would goto their website and read the tutorials.
Mr. 973808 Posted February 4, 2007 Author Report Posted February 4, 2007 This was posted earlier too by Alpine....Thanks to David for explaining it all. (legend) L= length W= width H= hieght *= multiply /= division or divide by -= minus ok here is how you figure this out. now just to make sure you get this correct. make sure you adjust the measurements for the wood thickness, I Always take off 1.5 inches off my measuremeants ( I use .75 thick MDF) L * W * H = your answer your answer / by 1728 = your answer in cubic feet. port area W * H = cubic inches of port area ( or port opening) The length of the port will give you your tunning but before we can get that far we need to deduct the displacement of the subz so you would do this. your answer in cubic feet - your sub displacement = you internal air space before port displacement. ok now you know your internal cubic feet with subz in now open WINISD Pro. I dont use the exact subz most of the time because usually they arent in the Database, I find one thats close o it in specs and go from there. If you have never used WINISD pro your not gonna have alot of fun trying to figure it out, I would goto their website and read the tutorials. Thanks for the hook up. THE GRADUATE 10:18:2007
David Posted February 4, 2007 Report Posted February 4, 2007 hahaha yea man you beat me to it. its not real indepth, but its starts the learning process of how it all works.
Guest Nismofreak Posted February 4, 2007 Report Posted February 4, 2007 Or you can buy movies from caraudiohelp.com which help out alot
