I've seen articles describing the big-3 procedure say conflicting things regarding whether or not to use the frame as your source of ground. (assuming your vehicle has a frame)
On one hand its a large, solid conductor with tons of cross sectional area, that runs the length of the car. On the other hand, neither I, nor most people I know drill holes in the floor and route the amp ground wire to the frame in the back. Instead, most people use a large chassis bolt. (seat, seatbelt, cargo hook, etc..)
Here lies my concern. The chassis and frame are connected together with rubber bumpers, and a few bolts. Not exactly the best electrical connection in stock form. To me that seems best to just skip the frame altogether and use the chassis for the grounds in the big-3.
I'm even considering strapping the chassis and frame together underneath the car with some 1/0 near the amplifiers, to utilize both chassis AND frame. (and likewise up front) What are your opinions?
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
If you're gonna ground your equipment to the chassis/body of the vehicle then yes you should upgrade the grounds under the hood to the chassis/body. If you're gonna ground to the frame then yes you should upgrade the grounds under the hood to the frame. Most cars do not have a frame though. They're typically only found in trucks & SUVs.
your body mounts are rubber, not metal ;)
rubber doesnt flow current like metal ;)
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
That's one point I mentioned in the post. So why does this guide recommend using the frame:
http://www.gmtruckhq.com/sound-security/bi...pgrade-842.html
And Derrick824, good point. That's how I ran my big 3, to the chassis. I was wondering if I can improve upon this.
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
I plan to, down the line. But I've got a long list of things to buy right now so I'm trying to perform as many smart, cost effective solutions as possible before I go all out on nice-to-haves. :)
(p.s. steel is a pretty crappy conductor of electricity after looking it up!!)
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
  • Who's Online   0 Members, 0 Anonymous, 570 Guests (See full list)
