Well, seeing all these chopped and screwed songs that hit so hard, I decided to do that to any song I choose. I know how to slow it. But with bass boost and hz and everything. I would like some help on what is good for hz and db in bass boost, so it has more bass but doesn't sound bad at all. Please help.
sorry for being a n00b :)
4 18's, low power and lots of gay fur.
Team gg
Team DOA
My Videos :)
find the peak sub-bass frequency song (there will be multiple's), and add ONLY 3-4dB bass boost to those specified frequencies.
If it sounds like shit or you see the red volume bar, back off on the bass boost.
after importing mp3, highlight .5-1second where you know the bass is
goto analyze
plot spectrum
change to 16384
change to log
scroll over until cursor and peak are at the same hz
a loud song is 20-27db, sine waves are 27-30db
only boost like said above 3-4db at specified hz, otherwise u will see the top of the wave being clipped/cut off
that is distortion
u cannot make a song with little bass have more bass without jeopardizing quality
its best to find a good copy of the song, or get the cd and work from there
bass boost is not there to make a song with 13db@40hz go to 25db@40hz without clipping
look at bigpimpins how to tell if a song is clipped thread and read his input and look at my visual examples
that should help alot
goto analyze
plot spectrum
change to 16384
change to log
that is distortion
Yeah, I have read it, a lot of good tips. Right now I'm just slowing it to about -17 speed to -20 and not changing bass boost at all; it sounds quite good, I was messing around with the songs today. I didn't change the hz but it was at 200, is that bad?
Team gg
Team DOA
My Videos :)
what was at 200?
200 what?
id be glad to help if i knew what i meant
Well, it says when i go to bass boost: Frequency hz 200
then under the db. I think that is the default setting that doesn't do anything. but idk
Edited by Slapuhho
Team gg
Team DOA
My Videos :)
find the peak hz in the song using plot spectrum, then put that number in the bass boost hz, and the default is 12db, which u were already advised not to do
ur only going to be adding 3-4db at most, between 30-60hz likely... 200hz is what ur mids play mostly so obviously its not gonna do anything to the song, since u didnt listen to clearly stated directions about how to add bass boost at a desired frequency/hz and at what hz, not choose the default
not trying to be rude, just thought i was specific enough
Edited by decafcappucino
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
