IAMBUMP Posted February 10, 2009 Report Posted February 10, 2009 I am trying to find out what all fittings I need, I know the obvious 45's at the bag but I want the valves on the frame rail, side by side with 4 on each side (2 dumps, 2 fills). I have an idea how to do the air tank fittings, but how do you connect the compressors? Is it just a two sided male fitting? Quote If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
sully Posted February 11, 2009 Report Posted February 11, 2009 draw it out like a system diagram, mark each one and count how many of each. you can get compression fittings from Mcmastercar (i think thats how it is spelled) link for them is in the tool section of the forum. way cheaper than getting them from a airbag distributor or from Home Depot and takes them like 2 days to get it to you. Quote 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
NomaOnAir Posted February 12, 2009 Report Posted February 12, 2009 hoseandfittings.com is good to .. Quote
IAMBUMP Posted February 13, 2009 Author Report Posted February 13, 2009 i got it figured out by drawing things out and suicides diagrams but i went thru my wholesale guys. Quote If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
