ok question would it be better for max power deliverly to use just 2 agu fuse holders in line ? VS divided them up with blocks and what not?
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
o,... now i see how come some of these rules are the way they are lots of loop holes,..
so i should be great with a 40 & a 50, in one line. ?
NO!
This will not work.
If you put fuses in series the lowest one will blow first, so it'll pop when your current hits 40A = fail
If you put them in parallel, it will pop when half the current equals the smallest fuse = 80A = fail
Use a 100A fuse...
10.x volts fo' life!
NO!
This will not work.
Use a 100A fuse...
i cant use a 100 amp because ill will go over the max limit for runing in amature street class 2,
Edited by BassBoy69
6" Aero Ported Box
Pioneer Deck
that is confusing
R.I.P!
(Nov-29-2009)
92 explorer
current build
NO!
This will not work.
Use a 100A fuse...
Exactly. :) Or two 40's and watch the volume?
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
so i can run them inline BUT them both have to be the same ?
6" Aero Ported Box
Pioneer Deck
I ran a 50 and a 20 in my fuse holder and it did not blow and I clamped right at 100 amps current..
They have to be side by side inline will not work....weakest link will blow inline.
Edited by RHoughton1
'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
By the way what kind of vehicle will you be running??
well I will be using a 98 eclipse Spyder, yes, lol,
6" Aero Ported Box
Pioneer Deck
that is confusing
shit, I think that picture just gave me a brain tumor :blink:
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
