1. Product: Harrison Labs Flux Cap
http://www.hlabs.com/products/fluxpower/
2. Specs: 100a 16v DC-DC convertor
3. Description/Condition: Like new!! Place this unit right before your 16v battery bank in your trunk in your ride and what it does is take your car 14.xx charge and converts it into its set point charge which is about 18.2!!! Simple easy solution to have a 16v system and not change a dang thing under your hood!!!!
To explain how simple this is guys.. If i were to drive to a buddys house today with my flux cap and a couple 16v batts.. We could place the 16v batts in his cargo area.. Hook up his pos run to the Flux Cap then hook the flux cap to the 16v batt bank and presto!!!!! 16v system in under 20mins!!!!!!!!!!!!
4. Price: : $250 shipped!!!!!!
5. Pictures: For now till i cant snap some with sn and date.. build pics from this last week..Its the little silver box in left side of trunk..
http://team-blend.net/x/Scottys_Build.html
Edited by ssackett
Team S.S.C.
DB Drag Street A 2011 National Champ
DC Audio Dealer
Nor Cal AA Dealer
Incriminator Audio Dealer
CA Sundown Audio Dealer
[email protected]
were are you located
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
so basically i could run 16v batts w/ this??
is there a catch?
they are limmited to the ammount of current they can provide.
they just step up the voltage
say you have 100 amps at 14.4 volts which is 1440w
say you have 18.2 volts you would only get 80amps at 18.2v
basically works like a ac power transformer
DC.jpgDC POWER
thanks, i get it now
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
This topic is now closed to further replies.
