Stock Head Unit, Adding An Amp
hey guys, I have a friend who wants to install a system in her mazda 3. I don't know the year just that she doesn't want to swap out the stock head unit because she wants to keep her navigation. I'm pritty sure to add an amp to a stock head unit you use a line out converter but I'm not sure, I've never had to deal with this because everything else I've done hasn't had the stock head unit.
thanks in advance and sorry if this is a simple question I've just never had to do this
idk if this will help but u can look here http://www.sonicelectronix.com/cat_i466_fa...ntegration.html
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Yeah just use a line out converter. She most likely doesn't have a sub-out so just clip to the rear-out and run that into the converter and run RCAs back. Everything else should be the same.
The "remote" wire might not be blue like most kits, so make sure you have a schematic or just run it off ignition.
Hope that helps. That's what I would do anyways, :)
Need an install? Hit me up.
[email protected]
ok so what it seams like is you run the line out converter to a set of rear speaker wires? I might be off but thats what it seams like. I can't think of what else would be the rear out. I really doubt it has a sub out on the factory head unit but that would make it a lot easier.
sorry about the late response my computer sux
or u can get her a rf 360 and just use the high's 4 ur in put and use the rca's as ur out
my buddy used these when he done a bmw 750i, he did a full sq system in it and these was the only line out converters he could find that worked the best with factory headunits
http://www.darvex.com/SGN13/Stinger%20Adju...0Convertor.html use meade as a cupon and get a 10% discount i think
just tap into rear speaker wires or front and rear and run 2 of these and just run rcas to back n then speaker wires to front, and i think www.the12volt.com somewere has system schematic colors, i dled one from someweres on here from there but it was a few yrs ago, hope that helps
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
those are way cheaper than I was expecting. I was thinkin like $50-100
ok cool I'll tell her to get that one, thanks for all your guys help.
np man, and those come with a place to run a grount wire right in the middle between speaker wires to help cut down on ground loop noise also
np man, and those come with a place to run a grount wire right in the middle between speaker wires to help cut down on ground loop noise also, and they have built in gain controles that help out alot also
  • Who's Online   0 Members, 0 Anonymous, 2597 Guests (See full list)
