1 15 RE SX vs 2 RE SX 10's
15 members have voted
  1. 1. 1 15 RE SX vs 2 RE SX 10's
    • 2 RE SX 10's
      7
    • 1 RE SX 15
      8
What do you think?
ive been lookin at it for the last hour and cant decide what i wanna do. obviously would do a t-line for either of them. just cant decide if i wanna go with less cone area with less efficiency with more power or go with more cone area, more efficency, with less power.. also would need a bigger box for the one 15. but i think the 2 tens with the higher fs would have a better all around sound. Also the 1 15 is going to be moving way more air, but idk if that will have any kind of diffrence.
"An efficient speaker helps you maximize your available wattage. Believe it or not, a 3 dB increase in speaker sensitivity produces the same audible increase in volume as doubling your amplifier power. So when you're shopping for speakers, it always pays to check the sensitivity spec — especially if you have a lower-powered receiver or amp. "
the tens have about a 5 db lower efficiency then the 15 has. so that right there make wattage even out.
lets debate it.
10"
Electrical Q Value -Qes: 0.29
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.27
Free Air Resonance -Fs: 30.7 Hz
Equivalent Compliance -Vas: 21.8 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 85.2 dB SPL
Effective Piston Area -Sd: 310 cm^2 x 2 for 620cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
15"
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.7
Total Speaker Q Value -Qts: 0.38
Free Air Resonance -Fs: 27.8 Hz
Equivalent Compliance -Vas: 126.3 liters
Efficiency -SPL 1W/1m: 90.4 dB SPL
Effective Piston Area -Sd: 810 cm^2
Force Factor -Bl:
Edited by Clif
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
2 tens here
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
2 tens here
reason for this?
In Dash
Rear Flip Down
reason for this?
cone area
Team T3 Audio
Team Sundown Audio
Team O.B.M
cone area
2 10s is about 1 15...
I vote single 15 :good:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
cone area
the 2 tens have less cone area then the 1 15? did you read the post?
810cm^2 for 1 15
620cm^2 for 2 10s
Edited by Clif
In Dash
Rear Flip Down
810cm^2 for 1 15
620cm^2 for 2 10s
oops. yeah sorry jumped the gun! i'm a douche..
Team T3 Audio
Team Sundown Audio
Team O.B.M
two tens, higher FS and double the coil and heat dispersion
-Drew
uhoh_45 said:
lol
idk what to do i want the 2 tens for many reasons but i think the single 15 would just be better.
In Dash
Rear Flip Down
