Sounds like I will go check out the ones at autozone, I was going to order the side post adapter from Darvex, same one I have right now, but sounds like the autozone one is a bit bigger.
Should I heat wrap any of the wire?
I heat shrink everything. Mostly because I had a hook up lol but it turned out to be a life saver when a shitty crimp(I know) was giving way.
I plan on soldering all my wire terminals. Might use 0 gauge clips to hold the wire around the frame on the front of the car, and keep it away from the motor.
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Full 1/0 Gauge Throughout
Big 3
Here's an extended length terminal you might keep in mind. We carry the standard length post also.
GM Extended Length Post
Another cool option.
GM Battery Terminal Kit
Heat Shrink In All Sizes
the extended post would work if I were to put washers in place if I needed to right?
I'm trying to find a terminal with all 0 gauge acceptance.
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Big 3
Are you going to have any of the factory wiring harness used? Also, are you using crimp or "pro" style 0 gauge terminals? I'm out for night, I'll check back in the morning.
I'm just going to add onto the stock wire.
And using crimp style and going to solder them
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Big 3
  • Who's Online   0 Members, 0 Anonymous, 640 Guests (See full list)
