Chipped A Tooth In My Rearend
Guest digitalboy
id drive that bitch till it fell apart. then tow it
X2 It's already breaking/broke, might as well see what it's got left.
Haha i thought about it but dana 35s are c-clip axles if it comes apart or breaks the axle rod the tire will walk away while im drivin. that wouldnt be so hot so she is just posted for now...Anyone have a Dana 44 set up for a jeep? lol
98 Jeep Wrangler
33x13.50 super swamper LTB's
Memphis M3 15"
Memphis MCD1000
Optima yellowtop D34/78
Bass Race 129.9
(LBZ Duramax in the future)
"Chipped A Tooth In My Rearend"...................being the idiot i am, this sentence caught my attention as being a bad skiing accident! lol. sorry about your ride, just thought i would throw some humour your way. good luck.
My daughter's (kimberly) hairtrick via the duckman
Dana 44 = good choice, however if you don't have about a grand to have a shop build one and professionally install it for you you're outta luck. I SHATTERED a spider gear in the Dana 35 in my Cherokee. Best thing I recommend is look for a shop in town that deals only with differentials, I found one locally that sold me 2 spider gears and a carrier pin for 15 bucks, it took about an hour and some simple hand tools to get it done, the place also offered to open up my diff and take a look inside for free.
However if your speedometer is still working then you may not have blown a spider gear and it could be an axle gear that broke a tooth off, this happened to me too, when that happened I just welded the whole rear end locked and decided to buy a replacement axle for when I snap this one. Good luck.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
gust pull the diff and look see what it is i would look for a ford 8.8 out of a 96 or newer explore you could get it for 400 all day long that is what i put in my 92 yj it is gust as strong as a dana 44 it would cost you about 600 in all and you cant get a dana 44 cost that
thanks for helpin out yall. I am plannin on tryn to drive it back to my farm in a couple weeks for spring break and leavin it there until the summer when i can get alil money to put somethin better under her. haha guess i will post how the drive went later
98 Jeep Wrangler
Memphis M3 15"
Memphis MCD1000
Bass Race 129.9
Best of luck, after I exploded the spider gears in my D35 I was able to drive it still by putting it in 4wd, if you break down put it in 4 and drive front wheel.
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
Hey whats man. Its me again haha
When you need to drive it back to your farm, just pull your rear drive shaft out and use four wheel drive.
It will be just like a front wheel drive car!!
1995 Jeep Yj
Rubicon Express Lift
BFG Tires
Warn 9000lbs Winch
KC offroad lights
1999 Mercury Mountaineer
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
Replace the factory head unit
^^ do that if you really don't wanna break anything :D
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
