Alright, I finally got some time to work on my kicks since I'm between jobs again. I put on some more Everglass filler and blocked it. Next I will try laying on some Rage and getting it smooth so I can texture and paint them. Here's a couple pics from my phone.
97 Maxima SE
Bunch of shit going in, check out the build
Ok, I tried using Rage Extreme for the first time today on one of the kicks, I don't think I did too bad. After sanding I only found a couple of small spots I need to redo, but other than that I'm happy with them.
Here it is freshly coated.
And next to the can of Rage for size comparison.
Here it is after block sanding.
97 Maxima SE
I was able to get more work done today . The one on the left has a coat of rage on it, the one on the right is primed, sanded and ready to paint.
97 Maxima SE
A little progress was made today. Started doing resin 45's in the box. Once those are done I'll give the inside a little sanding to smooth out the resin on the walls.
97 Maxima SE
  • 1 month later...
Yea, that stuff is great to work with.
Where did you get the blue terminals at?
2012 Nissan Altima SL
DC M2 Lvl 3 12" with AR cone
DC 1.2K Amp
Kicker Sum8
Kicker 4 Gauge amp kit
XS Power D2700
1.5 Cubic ft net tuned to 38Hz
