BeatBox Posted February 20, 2009 Report Posted February 20, 2009 I recently got a 180amp alternator for my 00 Blazer. Im doing the "BIG 3", and wanted to know how ground the alternator. Would it be at the bolts where its bolted down and then to the battery or the frame?
ChevyBoy Posted February 20, 2009 Report Posted February 20, 2009 its grounded when you bolt it in. now if you want another ground, take a bolt that holds it in and connect a wire from there to the neg on the battery
troy Posted February 20, 2009 Report Posted February 20, 2009 just run a wire from the alt to anywhere that will make a good ground. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
