4dabetta Posted February 20, 2009 Report Posted February 20, 2009 Does anybody know the amperage of an alternator off a 09 impala. Also can somebody tell me if i was to put a 250 amp alt. on my car would i be able to get my correct voltage or would i have to use a missing link audio joint.
wL<3bass Posted February 20, 2009 Report Posted February 20, 2009 Not sure what the new impalas charge at but if you get an alternator with an adjustable regulator you can get w/e voltage you want. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
4dabetta Posted February 20, 2009 Author Report Posted February 20, 2009 Not sure what the new impalas charge at but if you get an alternator with an adjustable regulator you can get w/e voltage you want. Do they come with them or u have to buy em.Well the missing link audio help me out and do you know how much they cost?
Neo_frog Posted February 20, 2009 Report Posted February 20, 2009 Do they come with them or u have to buy em.Well the missing link audio help me out and do you know how much they cost? Just go to www.missinglinkaudio.com and call them. They'll have all the info you need for the MLA. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Guest Just_Rob Posted February 20, 2009 Report Posted February 20, 2009 Does anybody know the amperage of an alternator off a 09 impala. Also can somebody tell me if i was to put a 250 amp alt. on my car would i be able to get my correct voltage or would i have to use a missing link audio joint. It should be either a 125 amp Bosch or 150 amp Denso depending on which engine and how the car was equipped.. I havent seen an '09 yet so they may have changed over to a Valeo alternator but most likely not.. As for your voltage question, your car has GM's RVC system so if your looking to get normal voltage levels from either your stock alt or a high amp alternator up in the 14's an MLA module would be necessary.. Rob
4dabetta Posted February 20, 2009 Author Report Posted February 20, 2009 It should be either a 125 amp Bosch or 150 amp Denso depending on which engine and how the car was equipped.. I havent seen an '09 yet so they may have changed over to a Valeo alternator but most likely not.. As for your voltage question, your car has GM's RVC system so if your looking to get normal voltage levels from either your stock alt or a highamp alternator up in the 14's an MLA module would be necessary.. Rob [/quote/] thanks for all the information ima look into that mla thing and check it out.
