Wiring 2 Sets Of Comps
IAMBUMP
Can you use a 2 channel amp with 2 componant sets or does it need to be a 4 channel?
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
if ur using the crossover, and the amp is 2ohm stable by 2 channels... then yes
rms would obviously need to be doubled
so in ur case, 2 sets of rsds (iirc) would be great on 120-150w rms... some would say even more power
Yes u can, if the ohm load doesnt get too low for the amp.
i can get a jbl px600.2 and want it if i can use it on some rsd pg componants. i need to figure out those componant's load.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
the componants are a 4 ohm set. is it possible to wire them tweeters and all above 2 ohm? ive never wired componants before.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
anyone? can someone explain how to actually wire them. not just a yes answer. im told you can but noone tells "how" other than parallel. what do u do with the tweeters?
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
With components, the midrange and tweeter are wired to a crossover.
The 4ohm is is not just the tweeter, but its readed from the crossover.
So if u wire both set components together, it will be 2ohm, and thats ok because the jbl amp is 2ohm stable.
thanks man, cacom just doesnt cut it anymore. i just needed to know if the tweeters changed anything ohm load related. from what your saying it wont, so im good to go. thanks a lot.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
  • Who's Online   0 Members, 0 Anonymous, 1074 Guests (See full list)
