thegr8cody Posted February 8, 2007 Report Posted February 8, 2007 i have 2 18" btls in a single chamber box,its 12 cubic feet with 140 sq inches of port i was wondering if i only play one if it will effect the other sub,i only have the money for one of my amps right now so i was wondering if i can hook up one and not screw up either of the subs 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0
sean 371 Posted February 8, 2007 Report Posted February 8, 2007 That would definately have a bad effect on the other sub. It's doubling everything for it. Not something I would do. That's why I like separate chambers, so you can run only 1 sub if you have a need to. sry man theres not really a way around it unless you build a new box with 2 chambers, or just one single sub box. That's probably the best thing to do is to build a box for one of them. And let the other one sit until youre ready A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
pyro719 Posted February 8, 2007 Report Posted February 8, 2007 Just buy one of these crap 18's off ebay and use it as a passive radiator http://cgi.ebay.com/18-Inch-1000-Watt-New-...1QQcmdZViewItem
sean 371 Posted February 8, 2007 Report Posted February 8, 2007 Well he already has the other sub, or it sounds like it. And using a passive radiator in a box two times the size won't work. A passive radiator acts as a port, meaning that you still need the correct size box, and no port. You could use your second sub as a passive radiator, but not in that box. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
thegr8cody Posted February 10, 2007 Author Report Posted February 10, 2007 thanks,looks like a longer wait lol. 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0
jcm1689 Posted February 13, 2007 Report Posted February 13, 2007 just hook up both subs of the one amp for now. it wont hurt to underpower them as long as you keep the gain on the turned down alittle so it doesnt clip. this should be just as loud as runnin just 1 and then you dont have to wait R.I.P. KOOLAID KING --- Thomas Johnson 04/02/1986 - 06/09/07 THUNDER CAR AUDIO Chris's 91 hatch - 2 18" BTL's, 2 T40001BD's, 153+ dbs Chris's 2005 BMW 525i Chris's 2002 Ford Ranger 2004 Silverado Blow Through 1999 Silverado - 4 15" SSD's Fiberglass Top Infinity G20 *RIP KOOLAID KING* Dodge Stratus - 2 12" Power HX2's, Fiberglass Baffle
