takenotes101 Posted February 25, 2009 Report Posted February 25, 2009 if im running 2500 rms would it be better to get dual batteries - maybe stock up front and xs d3400 in back. or should i get a 250 alt with stock battery up front?
CR Boom Posted February 25, 2009 Report Posted February 25, 2009 You will need both, Alt first then battery...IMO 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
jlgn_2000 Posted February 25, 2009 Report Posted February 25, 2009 I say you should always do the alt first. 94 3000gt 18" Kicker Solo X KX2500.1 2 KX350.4 8 JBL Coax Speakers 250A Mechman Alt
takenotes101 Posted February 25, 2009 Author Report Posted February 25, 2009 You will need both, Alt first then battery...IMO would i be fine running it on just upgraded alt and stock battery for a lil while?
CR Boom Posted February 25, 2009 Report Posted February 25, 2009 would i be fine running it on just upgraded alt and stock battery for a lil while? Better on upgraded ALT,,,, than two batteries getting no charge.. 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
takenotes101 Posted February 25, 2009 Author Report Posted February 25, 2009 Better on upgraded ALT,,,, than two batteries getting no charge.. i dunno if it matters but mine has about 145 amps or so right now
c0smo kram3r Posted February 25, 2009 Report Posted February 25, 2009 Well I plan to run my stock alt at first (150A) with a Deka 9A31 (PM to darn expensive even though you get what you pay for) in rear. If that doesn't work out, then I'm going to buy another Deka 9A31 for under the hood (already measured & it fits with room to go lol). If all that doesn't get enough voltage, then it's finally alternator time. Mine is for 2200w BTW.
takenotes101 Posted February 26, 2009 Author Report Posted February 26, 2009 so if i do get a new alt... id obviously run 1/0 from alt to batt and fuse it with a 300 anl fuse.. then id do 1/0 for batt ground, then 1/0 from engine block to chassis... would there be any chance that something would short circuit? or would i not have to worry about any problem at all?
Guest Just_Rob Posted February 26, 2009 Report Posted February 26, 2009 so if i do get a new alt... id obviously run 1/0 from alt to batt and fuse it with a 300 anl fuse.. then id do 1/0 for batt ground, then 1/0 from engine block to chassis... would there be any chance that something would short circuit? or would i not have to worry about any problem at all? Done that way, no problem at all... That's the way to do it up right!
