yea its fine
ok yeah i know its fine ????? i do it all the time im not a noob no offense just trying to help others
must be nice huh
gotcha
DC.jpgDC POWER
Ya i'm pretty sure C 45 knows his shiat :D Nobody else have any input or can tell me why the relays I searched have 2 numbers or have pics of there relay setups?
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
pretty sure the 2 #'s are for the 87 terminals. 87 would be 30a and 87a 40a.
85 and 86 go to a small magnetic coil that when you have power to it pulls a contact over and give you continuity from your 30 pin to you 87, when the coil is not energized the contact rest on 87a and what ever you have on 30 will flow to 87a.
20/30 amp will be more than enough but 30/40 amp will work too.
DC.jpgDC POWER
so you could have 30 amps flow through your relay before it reaches capacity. with a 30/40 or 20 amps with a 20/30. but i doubt you need more that 1 amp of current
DC.jpgDC POWER
Ok thanks for info
Passport Build Here
