heres a link to my build thred Visit My Website my ? is i have a stock batt up front with a 300amp fuse and 2 hc 2400's in the back running 2 rd audio 3250.1 amps the 300amp fuse up front is the only fuse
i have never did a meca comp but reading the rules i think i might be in m5 becouse of the 1 fuse but my amps are rated @750wrms @4ohms i would like to make the m3 class but what will i have to do im confused with all this any help please
Edited by fast85_gt
What subs do you have? Two 15s? Two 18s? With two 15s in MOD3, you can run up to 164 amps of fusing. With two 18s, you can run up to 149 amps of fusing. You can spread that load across up to 3 smaller fuses. The fuses need to be within 18" of the amp.
Team Carlisle Acoustics - Team Sundown Audio
2010 MECA DB3 World Champ 127.2
2010 MECA DB3 KY State Record 127.3
2009 February MECA Member of the Month
2008 MECA DB2 World Champ 131.9db
2008 MECA DB2 KY State Record 129.1
2008 MECA Neighborhood Nuisance
2007 MECA AS2 KY State Record 144.2
i have 2 18's but when i got my car metored with the termlab they put it right on the windshild but in meca they say it goes in the seat will this give you a higher score then on the windshild
You probably need in-line fuses within 18" of the amps.
can you anwser the ? above about the termlab
and i guess meca is about who has the best fuse lol
ya Meca meters at the hedrest it kinda depends how you are set up as to wich is louder typicly the dash is louder
You have to have a fues within 18" of the sub amp. That is the fuse that they use to determine what class you are in. If you do not have a fuse there, you will be put into a 5 class.
My vehicle loses 0.1 dB MECA style - most vehicles lose more, it is not very common to gain.
There are new rules on fusing to make it harder to just use "the best fuse" - I can burp four 3000Ds @ 16v on four 80-amp Sound Quest ANL fuses at hit 154.0 MECA styel.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
