rumproast789 Posted February 26, 2009 Report Posted February 26, 2009 I have it hooked up, well I took it out of the car. I tried it on 2 different amps, one I KNOW is working at 1 ohm (hifonics 1200d) and my sub wouldn't play. The Hifonics would immediately go into protect mode when the music started to hit the bass. The DMM says .7 ohm, maybe something is messed up. Here is how I have it wired: (it was originally this) But now come to think of it, I might have mixed it up, with the 1st postive and 2nd negative connecting to the positive output on the box. and then the 1st negative and 2nd positive connecting to the negative output on the box. I Don't know if thats what I did, but would either of the ways those were wired, do that to the amp? I wouldn't think the first one would, would it? Also, how would I take the sub out of my box? what is the best and easiest way to do it? It is flush mount so it's pretty tight. What way do you guys do it...? 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
Decaf Posted February 26, 2009 Report Posted February 26, 2009 ill make it simple for next time parallel dvd wiring of 2ohm sub to 1 ohm load connect both + sub terminals then go to amp +(however u please, with two equal length wires, or a jumper) same with negative all you are doing is giving the electricity 2 paths, instead of 1 path.... thus lowerin the resistance or ohm load(in lamens terms) both pictures are fine above are correct parallel wiring some 2ohmdvc subs will read 1.4-2ohm on each terminal, so half that... and u get .7-1ohm, so trust ur instruments, but dont trust your wiring, double check everything, especially when using a box terminal
rumproast789 Posted February 26, 2009 Author Report Posted February 26, 2009 ill make it simple for next timeparallel dvd wiring of 2ohm sub to 1 ohm load connect both + sub terminals then go to amp +(however u please, with two equal length wires, or a jumper) same with negative all you are doing is giving the electricity 2 paths, instead of 1 path.... thus lowerin the resistance or ohm load(in lamens terms) both pictures are fine above are correct parallel wiring some 2ohmdvc subs will read 1.4-2ohm on each terminal, so half that... and u get .7-1ohm, so trust ur instruments, but dont trust your wiring, double check everything, especially when using a box terminal thanks a ton. I opened it up, it looked like the - and + might have been touching after i tightened them down! so ill drill another hole a little farther apart. Hopefully that will do it! 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
07sOnAtA sp.ed Posted February 26, 2009 Report Posted February 26, 2009 ill make it simple for next timeparallel dvd wiring of 2ohm sub to 1 ohm load connect both + sub terminals then go to amp +(however u please, with two equal length wires, or a jumper) same with negative all you are doing is giving the electricity 2 paths, instead of 1 path.... thus lowerin the resistance or ohm load(in lamens terms) both pictures are fine above are correct parallel wiring some 2ohmdvc subs will read 1.4-2ohm on each terminal, so half that... and u get .7-1ohm, so trust ur instruments, but dont trust your wiring, double check everything, especially when using a box terminal well said CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
rumproast789 Posted February 26, 2009 Author Report Posted February 26, 2009 well said for sure it made me understand it completly, well for the most part 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
rumproast789 Posted February 26, 2009 Author Report Posted February 26, 2009 bump, is the reason the amp went into protect because the negative and positive speaker wires might have been touching? or could it be that the sub is damaged? 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
Boon Posted February 27, 2009 Report Posted February 27, 2009 bump, is the reason the amp went into protect because the negative and positive speaker wires might have been touching? or could it be that the sub is damaged? If the wires were touching the amp would go into protection 10.x volts fo' life!
