Mulitiple Amps To 1 Woofer
SubSonic
Ok well like the title says, i was just wondering if its fine to run the leads of 2 or 3 amps to one woofer terminals?? is this bad or can i damage the amps?? please lmk thanks!!!
Your amps need to be stappable, and you could hook 2 amps to one sub, use a dmm to gain match the amps and put one on each coil. But i would just strap the amps if they are capable of it.
Also i think maxxonics has something called a maxxlink, i think it match the outputs of 5 or 6 amps. but im not sure on it.
well few things to consider are the amps strapable? if not if your sub is a DVC
you can run one amp to one coil and another to the other coil, but then you would
have to gain match which isnt always reliable and easier to cause coil damage
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
also, when your tunning mutilple batts, and a cap or 2 caps, do the batts come first then cap then the amp??
Yea battery, to cap, to amp.
the battery gives the power reserve to the cap, and the cap gives it to the amp.
But it doesnt seem like there is a use for caps when you already have another battery.
pretty sure you might short something connecting leads from different amps.. unless the amps can be strapped together like rockfords bd sync but even then your only using 2 leads................ But then ive heard of ppl using 2 of the same amps and hooking 1 to each coil (on a dvc sub) I wouldnt recommend it.
you could put upwords of 4 amps to 1 sub
M= master S= slave
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
