dlheights Posted February 8, 2007 Report Posted February 8, 2007 I am planning a build for 4 12" Kicker L7's to go into a 2003 Trailblazer and wanted to know if anyone has some good box designs for them. I'd like as much detail on sizes and internal port info as possible. I will get measurments of the suv as soon as I can. It's way too cold for me to be out there in sub zero temperatures (<-litterally) measuring. I'd like to get around 3-3.5 ^3ft of space if available. It will be daily driving, and a few comps and I'm not worried about SQ as much as SPL. BTW dlheights = newb box builder, but gonna try ;D. I'm also planning on doing a lot of fiberglass research if anyone has a good thread for me to read up on. Thanks in advance for the info.
sean 371 Posted February 8, 2007 Report Posted February 8, 2007 3.5 cu ft is waaay too small for 4 l7s. One 10L5 needs at least 2. So you're looking at at least 10 cu ft for those subs. Unless you want it sealed. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
dlheights Posted February 8, 2007 Author Report Posted February 8, 2007 3-3.5 per sub, sorry for not clairifying, lol. I was thinking 12-14 cubes, but dont know what i should do for a design and how to measure port size, most people I know use small ports (about 1" going across the entire box on the bottom). I am going to have them each in their own chamber as well. How far back should I go on the port wall. I really don't know how to word this so Ill draw a lil pic... ___________ ___________ | __ | __ | | | | | | | | | or | | | | | | | | | | | | | | | -[=]- -[=]- -[=]- -[=]- (thats basically what I'm tryin to say, I hope you understand that, should I make turns in it or just go back?) p.s. the pic is only two i know but i didnt feel like makin it for 4....
sean 371 Posted February 8, 2007 Report Posted February 8, 2007 3-3.5 per sub, sorry for not clairifying, lol. I was thinking 12-14 cubes, but dont know what i should do for a design and how to measure port size, most people I know use small ports ([glow=red,2,300]about 1" going across the entire box on the bottom[/glow]). I am going to have them each in their own chamber as well. How far back should I go on the port wall. I really don't know how to word this so Ill draw a lil pic... ___________ ___________ | __ | __ | | | | | | | | | or | | | | | | | | | | | | | | | -[=]- -[=]- -[=]- -[=]- (thats basically what I'm tryin to say, I hope you understand that, should I make turns in it or just go back?) p.s. the pic is only two i know but i didnt feel like makin it for 4.... The normal rule of thumb is to try to stick with an 8:1 ratio of width and length. So basically with a port that skinny and long, it'll get a lot of port noise. In theory, the more square you can get it the better. Your port length is dependent on the port area (and other things), so I couldnt really tell you. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
