I'm having a problem with my new head unit. I own a 1989 Honda Civic DX hatch. Just bought an Alpine CDA-9884 saturday and KNOW it works because I purchased it off the wall. I wired up the harness, plugged it in and nothing. Checked my wiring and tried again, nothing. Re-checked wiring, checked fuses, nothing. Swapped fuse on head unit and radio fuse in car, nothing. I can't figure out my volt meter so I couldn't test it but I did undo the ground from the harness and tried against metal on car, it sparked, held it there and still nothing. I've gone back and checked for loose wires on harness, and connection to battery from factory wiring to harness. Does anyone see something I may be doing wrong? Or is there anyone out there with the slightest idea of something I'm missing? Any help is greatly appreciated.
Thanks.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
are you sure you have accessory wire running into the stock harness??
hook the red and yellow together. if it comes on then you'll have to run an accessory wire to the ignition harness for when you to the key it turns the radio on.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Going to check on that now.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Nothing. I did it from the back of the H/U to the new harness. Should I be doing it from the car harness to the head unit?
Edited by camino_1to3
Team T3 Audio
Team Sundown Audio
Team O.B.M
Nobody can come up with anything? Come on guys! Pleaseeeeeeeee
Team T3 Audio
Team Sundown Audio
Team O.B.M
have you tried to hook this up straight to a battery yet without any vehicle wiring in the loop ?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
When i had my 9813 sometimes i would have trouble with it. After disconnecting it to do some work or whatever and reconnecting the radio back when i was done it wouldnt work. A couple of times i thought i blew it but after messing with and disconnecting the harness after awhile it would work. Still puzzled about that to this day... :unknw:
No, power and ground to one terminal right though? Or power to pos. and ground to neg. or metal in bay?
Team T3 Audio
Team Sundown Audio
Team O.B.M
The filthy whore works now fuckkkkk YEAHHHH!
Team T3 Audio
Team Sundown Audio
Team O.B.M
