over 1000 id say is where to consider alt or batts
it really depends, my buddy got a crown vic interceptor and it came with a 180 amp alt, all he needed was a new batt up front to run 2krms
my car needed a batt and alt to get 1500 running
it matters case by cass, but somewhere around 1000-2000 watts you should conssider batts and an alt
and as for the whole 16v thing, please, dont do it. yes it seems simple, yes you *could* do it, jut dont. its a bad idea, a very very bad idea. Especially if its one of your first systems, or you're like in highschool trying to be the big baller in the parking lot. chicks dont dig dudes with rides that catch fire, or burn out every bulb and relay.
Team DC
k thanks man
im just tryin to get as much info before i do anything so i dont burn my car to the ground
but how do i know if my car would need another battery? like lights dimming and obvious voltage drops?
Bass is my drug. One hit and i was hooked.
i totally see something getting fried soon
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
o no the guy at the beginning that didnt know what preamp voltage was.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Hrm I really need to post the post I've been planning about why batteries won't stop your lights dimming...
I had a setup at close to 5000wrms on just a single Datasafe HX400 with stock 90A alt ;) 8 runs of 0 gauge might have helped a little I guess :P
10.x volts fo' life!
