Ok well fisrt
What is pre amp voltage?? that the power cable voltage to the amp from the car batt??
and how do u boost the "pre amp. from 12 to 14 to even 16?? do u need a relay or what?? lmk thanks ALOT!!!
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
voltage going to the RCA's
you dont want 12 14 and 16 volt preamp voltage, youll fry near any amp with that preamp voltage
Edited by James
Holy shit. I hope you research before you start sticking stuff together.
Preamp is the voltage in the rcas that run from the deck to the amp. Your thinking of dc voltage coming from the batteries. Most head units have a 2v preout. Others have a 3, 4, 5, and even 6 volt preout. That just means that your amps will run cleaner as your sending more of a signal to it and this will allow you to adjust your gain better. 12v and 14v sytems are what people run to get more power out of there amps. Your normal daily driver is a 12 volt system. You can achieve 14 or 16 volt systems by buying 14 or 16 votl batteries. If you run a 16 volt battery in a daily driver you can fry all of your eolectronics if you dont have it isolated to the trunk and amps only.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
Thats not true either, If your headunit is cheap garbage and is sending a distorted signal then 2volt or 100volts isn't going to make it cleaner. Higher voltage helps push the signal along the the rca's and the higher the better when dealing with distrubuting it or longer lengths.
Ok well on the SoundStream 6500, it can push 5000 at 14V and 6500 at 16V?? whats the voltage called??
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
no, 14v and 16v on those amps means how much power it can accept from the battery. if you do that w/o knowing what your doing you will fry your whole car electrical, or damn near risk it blowing. preamp rca's sends the music signal from your music source (headunit/dvd player etc) to your amp input. that, in turn is amplified by the.... ampflifier, which is powered by your car's charging system. then the amplifier outputs that amplified signal to your speakers.
