dwright27 Posted March 7, 2009 Report Share Posted March 7, 2009 ok so im wanting to paint my port a pearlescent/nice gloss/metallic white with a few layers of clear, and green LED's throughout it. what im wanting to know is if you guys think 50 is gonna be enough to do a 8" x 32" port? nd do you think its gonna be bright enough to light everything up? heres a link http://cgi.ebay.com/ebaymotors/50PCS-12V-R...#ht_2446wt_3883 Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
lowrider77 Posted March 7, 2009 Report Share Posted March 7, 2009 50 will be well more than enough i had 28 in ma old box 36x16x18 and it lit up the box good and it was only white melamine inside Quote Link to comment Share on other sites More sharing options...
The Performer Posted March 9, 2009 Report Share Posted March 9, 2009 Pics would help bro. Now if I'm correct, you want to put the LED's in the box shined into the port? Also, You'd probably get a better glow effect if you were to find LED's that are closer to 360 degree shine. They wont be clear, but will be the opaque kind. Or, what I've done MANY of times is just use a fine steel wool, and spin the LED in the steel wool to rough up the surface and break up the light better. Quote CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
dwright27 Posted March 9, 2009 Author Report Share Posted March 9, 2009 Pics would help bro. Now if I'm correct, you want to put the LED's in the box shined into the port? Also, You'd probably get a better glow effect if you were to find LED's that are closer to 360 degree shine. They wont be clear, but will be the opaque kind. Or, what I've done MANY of times is just use a fine steel wool, and spin the LED in the steel wool to rough up the surface and break up the light better. would like to mount them in the port like with the bulb in the port and the wires hidden behind the wood. basically a hole drilled big enough for the bulb and cover to go through and hot glue to seal it back up and hold it. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
