Torres Posted March 7, 2009 Report Share Posted March 7, 2009 (edited) ok so i finally decided to start redoing my center console. it's not going to be anything tooooo fancy. just displaying a volt meter, some switches, relocated a cup holder and a new compartment. there's my volt meter. it's red, not purple fyi console out UGLY wiring mess. ew...time to clean that up much better got rid of the controls and braced it at first i was just going to chop up a little of my console and just kinda jazz it up. the more i thought about it, the more i figured i should start from scratch. so i threw that piece away in the last few pics this piece will be kept tho. Edited March 7, 2009 by ExpoSport Quote Link to comment Share on other sites More sharing options...
stereomayhem Posted March 7, 2009 Report Share Posted March 7, 2009 Sounds like a cool project, get rid of those wire nuts though! Quote www.stereomayhem.com Link to comment Share on other sites More sharing options...
Torres Posted March 7, 2009 Author Report Share Posted March 7, 2009 the cup holder i'm keeping the base few layers of glass on it drying in the light got it out and trimmed up now those lil triangles you see, they're cut out like that to allow me to slide it in to place. there's 2 screws at the front i'm not going to be using since i wont have a top piece that pops off. so the whole thing needs to slide into place there's the bolts sitting in then slid into place Quote Link to comment Share on other sites More sharing options...
Torres Posted March 7, 2009 Author Report Share Posted March 7, 2009 Sounds like a cool project, get rid of those wire nuts though! hahaha that's the plan. it was done a LONG time ago. i honestly forget what it goes to. everything else i was able to trace and take out. but when i start wiring all the odds and ends together i'm going to solder them. gonna find me some heat shrinks as well Quote Link to comment Share on other sites More sharing options...
Torres Posted March 7, 2009 Author Report Share Posted March 7, 2009 (edited) the wood isnt quite as crooked as it looks get both pieces back in i glassed em together, but forgot to take pics this piece is going to get molded to the other factory piece, so it butts up to the dash without me having to do extra work Edited March 7, 2009 by ExpoSport Quote Link to comment Share on other sites More sharing options...
Torres Posted March 7, 2009 Author Report Share Posted March 7, 2009 (edited) there's the new compartment just mocked up together. it's going to have a false floor so i can put the console in, screw it down at the base, then put the floor in that's my cut line to kinda blend it in to the factory piece and where my cup holder will be. and add some curvage these tabs are what will hold it up. they'll be glued in and probably glassed in a little cuz i dont want them falling off. would be a HUGE pain to have to fix. i have a few more pics, but i gotta get ready for work. so i'll post them tonight probably if i dont end up going out Edited March 7, 2009 by ExpoSport Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 7, 2009 Report Share Posted March 7, 2009 looks good hopefully it will be done before your walls done Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Torres Posted March 7, 2009 Author Report Share Posted March 7, 2009 looks good hopefully it will be done before your walls done hahaha shut it! my amp is on its way back...so i'm happy bout that. Quote Link to comment Share on other sites More sharing options...
00sdime00 Posted March 7, 2009 Report Share Posted March 7, 2009 looks good hopefully it will be done before your walls done Buuuuuuuuuuuuurn....... Looks like you got a good start so far....do work son Quote A half-wit gave you a piece of his mind, and you held on to it. My Youtube vids...enjoy anythings possible with the right build =] we accept visa and mastercard =] Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 7, 2009 Report Share Posted March 7, 2009 seriously though, its a good start and what kind suv do you have again, a ford escape? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
