That box turned out nice.
Sundown SAZ-3000
2 12" T3 DVC1ohm subs
58hz peak cabin frequency no deadner yet
box tuned to 38hz
BIG 3 upgrade
yamaha patio speakers rear fill
Alpine 9833 deck
PPI FRX-456 Crossover
PPI PAR-245 Preamp/EQ
PPI DEQ-30 Band EQ fronts
PPI tweets in kick panel
PPI 2-way's in kicks for now
0/GA 1 run front to back
Memphis 4 channel running rear speakers 75 X 4 only 2 channels used for now
Planet Audio 4 channel 75 X 4 running front speakers
146.7 db usaci drivers door open
163.3 db port challenge mic in port
2012 4door silverado
Thanks guys :)
no 45 or IN the port?
Look closer...you might see it ;) (there is a 45 in the port itself if that's what youre asking about)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
