JPM75 Posted March 13, 2009 Report Posted March 13, 2009 Anybody have a good idea/product for fixing a gas tank? I have a 2000 Chevy Tahoe, and I noticed a strong smell of gas today after i filled up. When I got to the house, I checked the cap, it was fine, then I got under it to take a look. It looks as if it is leaking from the top side of the tank. (its on the side, towards the top, next to the frame.) Any advise would be great! Quote "loud 'cause its clipped like a 7yr olds buzz cut" -Decaf "unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
JPM75 Posted March 13, 2009 Author Report Posted March 13, 2009 JB weld it real good. Do they make some for plastic, more importantly, for gas tanks?? Quote "loud 'cause its clipped like a 7yr olds buzz cut" -Decaf "unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
banginAltima Posted March 13, 2009 Report Posted March 13, 2009 Replacing it is the best. It may only be a seal as well. The last thing I would try is the stuff big rigs use on their tanks (can't think of the name). You can find it at truck stops. Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
RamenNoodles Posted March 13, 2009 Report Posted March 13, 2009 Get that shit that Billy Mays sells. Mighty putty rofl. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
audioman21 Posted March 13, 2009 Report Posted March 13, 2009 II had the same problem about a year ago, I used the the pack with the red and black tubes. You can get it at walmart in the automotive section or an auto parts store. Find out exacly where(or close) to where its leaking, clean it up a little with a old rag. Then get you some latex glove, mix the two tubes together then using your hand coat it on. You might need to coat it a few times to seal it up all the way. Quote
badasschevy Posted March 13, 2009 Report Posted March 13, 2009 i'd check the filler hose for the leak, if its the tank itself(pinhole or crack) you can rub a bar of soap over the area and it'll stop it for a little bit, otherwise you'll have to replace the tank,or have a shop weld up the area. Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components
JPM75 Posted March 13, 2009 Author Report Posted March 13, 2009 Get that shit that Billy Mays sells. Mighty putty rofl. UUhh....NO! Thanx but no thanx! Billy Mays can suck it, with his OxyClean, and all that other "AS SEEN ON T.V." STUFF. LOL Quote "loud 'cause its clipped like a 7yr olds buzz cut" -Decaf "unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
JPM75 Posted March 13, 2009 Author Report Posted March 13, 2009 II had the same problem about a year ago, I used the the pack with the red and black tubes. You can get it at walmart in the automotive section or an auto parts store. Find out exacly where(or close) to where its leaking, clean it up a little with a old rag. Then get you some latex glove, mix the two tubes together then using your hand coat it on. You might need to coat it a few times to seal it up all the way. i'd check the filler hose for the leak, if its the tank itself(pinhole or crack) you can rub a bar of soap over the area and it'll stop it for a little bit, otherwise you'll have to replace the tank,or have a shop weld up the area. Thanx guys! I cant say I have ever heard the bar soap one. If I cant fix it, I'll just replace it! Quote "loud 'cause its clipped like a 7yr olds buzz cut" -Decaf "unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
wildbeast15 Posted March 13, 2009 Report Posted March 13, 2009 best idea is just to replace it.... sorry but i wouldnt fuck with leaking gas lol..... Quote The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)</div>
