I was wondering if there is a thread or website or something that explains how to run multiple wires from the hood to the trunk to connect multiple batteries. i was wondering the benefits/downfalls of having multiple wiring or just one. thanks
Team Bass-Hz
Multiple wires is just to add more copper for a better flow of juice. Youll have to fuse every + wire.
For wiring it to multiple batts: Just run wire from the + terminal under the hood to the + terminals in the trunk. and ground all the batteries.
you should really have two fuses in the wire if you are connectin batteries
batt....fuse.............................................fuse......batt
if you just have batt......fuse..............................batt
-----------------and you have a short here ^ -------^that battery is still shorting out
is there like a special battery terminal i need to be able to run multiple out of my main battery under the hood?
yes and no. You can spend money on battery terminals that have multiple 0 guage inputs, which is what i started out doing.
or. what i do now: just get some heavy duty battery terminals from walmart or autozone. I got some from walmart that accepts up to 1 2/0 gauge wire and has two bolts to hold down the top. so i use the one 2/0 part for one wire and bolt wires with ring terminals on the two bolts that hold the top on.
Posted (edited)
here's an idea..
If youre lucky enough to have some sort of sideskirt panel on your car like mine...you can fit plenty of wire in them..
Power runs..
Ground runs..
And the sideskirt goes right over them...never would know theyre there..
As for connecting them all...you'll probably want to make/have someone make you some busbars, something along these lines..
And dont forget the fuses and fuse holders...once you step up to multiple runs in a daily driver...you'll need fuses on each end of your power runs (assuming you have batts in the rear), which really adds up in cost :(
But good luck...and you can find copper for busbars at stormcopper.com ....they have a great selection and good prices imo
Drilling holes in the copper and then tapping them will make life really easy on you rather than bolting the ring terminals to the copper...just have to find some short bolts/cut down some bolts and youre set :)
Edited by Pioneer~Saturn
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
here's an idea..
Power runs..
Ground runs..
nice set up :)
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
Thanks :) It gets the job done
It was plenty of work...but it's worth it
Team Tupperware
yea that is very nice work. Thanks a lot for the pics. really helps :) One final question, I have 1 yellowtop in the front of my car and 2 in the back. How should i connect all the wires? something like this (sorry about the bad drawing) :01nocomment8so:
Team Bass-Hz
here's an idea..
Power runs..
Ground runs..
That all looks great man, but next time you might wanna use all black UV resistant zipties and wire tiedowns. I say next time, and I hope for your sake there is no next time, but most likely after a few summers those will get brittle and break.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
  • Who's Online   0 Members, 0 Anonymous, 1017 Guests (See full list)
