bluee6 Posted March 17, 2009 Report Posted March 17, 2009 how many volt can u run up to in the power master battery? Quote
scottiej Posted March 17, 2009 Report Posted March 17, 2009 how many volt can u run up to in the power master battery? The 12V models should not be charged above 14.9V, the 16V models should nto be charged above 19.2V Quote XS POWER Batteries, Chargers & Accessories 888-4XS-POWER
bluee6 Posted March 17, 2009 Author Report Posted March 17, 2009 The 12V models should not be charged above 14.9V, the 16V models should nto be charged above 19.2Vwhat should i used to seprated the front 12v batt from the 16v batt at the back ? i think about Stinger S2402 240 Amp 3 Post Battery Isolator will that work ? Quote
18inchjeepin Posted March 18, 2009 Report Posted March 18, 2009 scottie how come the intellicharger takes mine D1000's to 19.6? Quote HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
fritosaregood Posted March 18, 2009 Report Posted March 18, 2009 what should i used to seprated the front 12v batt from the 16v batt at the back ? i think about Stinger S2402 240 Amp 3 Post Battery Isolator will that work ? do you have a 16volt alt Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
bluee6 Posted March 18, 2009 Author Report Posted March 18, 2009 do you have a 16volt altyes i have a 16 volts alt Quote
bluee6 Posted March 18, 2009 Author Report Posted March 18, 2009 yes i have a 16 volts altwhat should i used to seprate the batt? Quote
Loudcav Posted March 18, 2009 Report Posted March 18, 2009 what should i used to seprate the batt?use a Stepdown modual Quote
loopkiller Posted March 18, 2009 Report Posted March 18, 2009 The PM/XS 16V stepdown box is what you will need. However, this device can handle 25A continuous/50A max, so if you are drawing more than that on your 12V side, you will need more than one. You will need one stepdown box per 25A of continuous 12V power your vehicle uses. This includes all of the stock onboard 12V electrical. Quote
bluee6 Posted March 19, 2009 Author Report Posted March 19, 2009 The PM/XS 16V stepdown box is what you will need. However, this device can handle 25A continuous/50A max, so if you are drawing more than that on your 12V side, you will need more than one. You will need one stepdown box per 25A of continuous 12V power your vehicle uses. This includes all of the stock onboard 12V electrical. i will be useing a 12v batt in front and 2 16 v batt in the back so how much stepdown box do i need ? Quote
