Good 400.1 1ohm Stable....
H 2 the eigel
At 400w you're better off wiring your subs to a different load (eg 4 ohms, if you can get 1 ohm you can almost always get 4 ohms) and then run a bridged 2-channel to it. You can get a 2 channel that will do 400w x 1 for much much less than a 400w 1-ohm stable monoblock will cost you.
EDIT: Plus when you upgrade you can use the 2 channel to run some mids but you can't use a 400w mono for sh!t.
10.x volts fo' life!
Good point thank you!
