Looking for someone to design me a ported box with kerfs will pay $20.00.
1 fi Q18 "
t8002 1000 watts
Fullsize ford van
52w x 23h x 22.5d
Optimum sound quality
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Edited by tyler2009
I don't take shit from no one.
i like the way they look and PERFORMANCE, sub up port back and maby mount the amp on the box.
Edited by tyler2009
Well I like that you are adventurous, but honestly, they are a lot of work. And they are even worse if you don't know how to do them. I agree with the subs up port back, or both firing back.
I guess I don't know where or how you plan on kerfing. I guess you could build a normal box and have one side of the sub as a port wall, but it'll be very tricky to build if you've never done it.
Why not start with sub up, port sideways with the front of the box plexiglass with a decal and some LEDs? That would be MUCH easier for a starter and would probably look better. Just make sure the port is "behind" the sub so as not to affect view of the motor structure through the glass.
How does that sound?
Need an install? Hit me up.
[email protected]
yea id go with what he said sub up port out the side would be sweet and some plexi always adds to the box looks great and its quite simple i was gonna try kerf cutting on my box but i decided to back down off that idea cuz i looked up what all had to be done and i dont have the resources neccesary not saying you dont but there alot of work and its no easy task bending wood lol but listen to this guy dont really know him but hes a good guy and seems quite knowledgable
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
he just wants a design.
if he thinks he can build it then more power to him.
where is this box going? in the back?
what do you want it tuned to? FI's specs?
do you want double baffle?
give me some idea of exactly how you want it and i'll help you out.
pm me.
edit:forgot the pm thing :censored:
Edited by brewer_brewer
Yes to fi specs yes double baffle sub up port out the side kerfs in the ports yes in the back.
Edited by tyler2009
