A wooden one.
Tell us a bit more... what's your budget, what organisation do you want to run in and which class, do you mind losing back seat or cutting metal?
10.x volts fo' life!
dont know why you would want to wreck
a charger rt with a spl set up go for a nice sq in that
car IMO
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
port/ subs/sub back box biult to specs
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Someones not a newb lol. Id like to see a good SPL build in a charger! Do the DD and I dont think youll go wrong. Just dont or have a hack job done. Would kill the whole cars appeal. If you decide to do a serious build make sure the trunk isnt sealed off from the cab. Port thru the back dash or seats. I hate rattles and flex on the outside then you stick your head in and can have a candle light dinner inside. Make sure the bass gets inside the car haha
Edited by LoudBlazer
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
I was thinking two digital designs 9512's. Have any ideas on the enclosure? All the trunk is available.
2 9512's in 4 cubes with a single 6" aeroport tuned to around 38hz will go crazy. EDIT: Still won't do 'SPL' numbers, maybe mid 140s at best...
Just make sure you have about 3000w for each sub and appropriate electrical to back it up and you'll be away :)
Edited by Boon
How long on the port legnth? Thanks
You want more than 4 cubes for DD 12s. And if this guy does it right, in an spl set up, it will meter more than mid 140s. Best advice I can give you would be go to the soundpressure forums. They know just about everything there is to know about dd. Good luck with whatever you choose.
Ps - don't make the mistake I did and try to play music on them daily. They ARE an SPL sub(atleast the 9500 series are)
  • Who's Online   0 Members, 0 Anonymous, 1521 Guests (See full list)
