Alright so I have two Orion D5000's that I bought new, If you are familiar with these amps they have 4 4ga power terminals, 2 positive and 2 negative.
Also the fuse holder is external from the amp, its a ANL type fuse holder and it is 4ga also, My question is, how do I wire the fuse?
Should I put the fuse on one of the positive wires and and one of them will be straight through and the other one fused?
It's confusing because I would think that for protection you would want the whole positive power feed fused and not just one of the power leads because if there was any kind of electrical fault/failure you would want the fuse to burn, but if I use the config I stated above, there will still be a power feed even if the fuse were to burn.
Let me know what you guys think.
yeah i would think you'd want fuses on both power wires, and someone correct me if i'm wrong, just saying
1997 Dodge Ram Van 2500
Big III addition with 1/0 awg wiring all throughout
Lightning Audio Strike S4.1000.1D
Jenson XA2250
2 - 12" Mtx Jackhammers JH55
3ft cubed box sealed under the rear bench seat
Pioneer DEH-P6000UB head unit
MB Quart FWA 160 components up front
Damn, I'm starting to regret getting these Orion amps, anyone else have experience with them?
why?...fusing is important
I would expect them to include the proper fusing for their amplifiers with the amplifiers or tell me up front that I will need to order a extra fuse holder because they are only including one and I will need two.
Sorry, I live on a island in the pacific ocean so shipping takes forever and when I have setbacks like this that could have been avoided it's kinda annoying haha.
Thanks guys for the help!
couldn't he get like a t-block after the fuse holder that goes to both amps, or would be be drawing too many amps through that fuse?
Jenson XA2250
250A fuse means its for both terminals ;/ 250A is what you use to fuse 0ga, not 4ga. Are you sure it doesn't have 1x0ga in and 2x4ga out, would make more sense.
10.x volts fo' life!
