FreelandKustomz Posted March 28, 2009 Report Posted March 28, 2009 These are the rules ONLY for the king of cali exhibition matches. Once we are done with the normal db drag and bass race points classes king of cali will start 1 hour prior(which ever location finishes last) so you have time to recharge and re tweak your systems. DB DRAG KING RULES: You will have 3, 30 second runs. Whatever your score is from each round will be taken, and all three will be averaged out. Your runs will be 30 SECONDS APART! so your best bet is only one burp per 30 seconds. You can start the car to recharge but must be off before your next run!! IF db drag rules say your car is normally allowed on during your run, then you are allowed to obviously keep it running. Turning it on and off only applys to classes that are normally not allowed to have the car on! Bracketing rules of coarse will apply. BASS RACE RULES: Two (or one) competitors will pull up in the lanes, two dice will be rolled twice. the first roll will be your 3rd number (IE 134, or 138) the second roll will be your decimal. If you go over the chosen number, you are disqualified, if you go under your class number (IE 130.0) you are also disqualified. if there are more than one person disqualified in your class, you will be able to go up against each other once everyone else in your class has run. If you are disqualifed and no one else is your in class to go against you, you receive no re tries. For example, if your in the 130-139.9 class, and the first roll is a a twelve and the second roll is an 11, you will have to hit a 132.1 no higher and no lower than 130. If you roll a 10 and roll a 9 you will have to hit a 130.9 and not go any higher, and no lower than 130! Therefore any number over 10 we will only use the last digit in that number. The dice will be rolled EVERY TIME a new competitor is in the lanes, and everytime you re enter the lanes. There fore each dice roll is unique to each pair (or single competitor) in the lanes Bracketing rules of coarse will apply. NO PSYCHLONE KING!!............Unfortunetly In the so cal location will be having Headrest wars, and port wars! we are playing for Prizes!!! if it gets heated cash money will get involved! Headrest wars will follow the NORMAL bass race rules of db drag, not king of cali rules, and port wars will follow db drag rules, not king of cali db drag rules! So burp your port, bass race your head rest! The headrest will be the passenger headrest. If you do not have a headrest, the top of your seat will be used. So bring your passenger seat headrest! The king rules will NOT be modified, this is the final rules post!!! Port wars and headrest wars can be modified until the day of because its a so cal only competition. Doug if you want to type up these rules and print them out for the competitors to read over when they sign up so they are aware of what king of cali entitles, please feel free! it will help with the newbies on the spot. PRICING BREAK DOWN!!!!!!!!!!!!!!!! Official Db Drag 3x Runs Db Drag 40 dollars (for points) Bass race 40 dollars (for points) both of those classes together is 60. Exhibition King Of Cali Runs King of Cali Bass race 50 dollars king of Cali db drag 50 dollars Both classes 75 dollars You can enter ONE bass race class per vehicle. If a competitor wants to run a separate vehicle in a different class, that is acceptable. additional fees will apply. HEAD REST WARS!! exhibition match for cash money! The mic will be placed by your head rest, 28 inches from the bottom of your seat. Seat must be placed in a comfortable realistic position. Your driver window and passenger window must be down. All doors closed bass race format. 30 seconds average will be taken. 10 bucks to play! Be at the so cal location between 9am and 11 am, we want to have you all qualified and registed before noon but it may end up taking much longer depending on how many competitors show up.
*1LOWSUV* Posted March 28, 2009 Report Posted March 28, 2009 DB DRAG KING RULES: You will have 3, 30 second runs. Whatever your score is from each round will be taken, and all three will be averaged out. Your runs will be 30 SECONDS APART! so your best bet is only one burp per 30 seconds. You can start the car to recharge but must be off before your next run!! So no matter what class your in, Vehicle is off? http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif [email protected]
Team Bassick - Kimo Posted March 28, 2009 Report Posted March 28, 2009 Can we get a fee break down per location? KIMO @teambassick http://www.teambassick.com
*1LOWSUV* Posted March 28, 2009 Report Posted March 28, 2009 Once we are done with the normal db drag and bass race points classes king of cali will start With these rollin dice car not running rules, I'll be headed home early..... http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif [email protected]
ALPINE408 Posted March 28, 2009 Report Posted March 28, 2009 So no matter what class your in, Vehicle is off? http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif I run ss5+ and your allowed to run your car for king I can't man I'm dealing with a high priced high powerd system I really would not want my car off for this Does that go for bass race another format that allows the cars to be on??? Have you ever had your woofers blown?
FreelandKustomz Posted March 28, 2009 Author Report Posted March 28, 2009 car is running IF Your class allows it. Its normal db drag rules when the 30 seconds is rollin and bass race car is on of coarse. only rule change is just the number you must hit or range you have to stay in. the car is only off in db drag because certain classes IE street b and street max you have to be off. I dont know if it was clear but Db drag and bass race are two seperate styles of rules. Alpine you can have your car on, your class allows it!
ALPINE408 Posted March 28, 2009 Report Posted March 28, 2009 With these rollin dice car not running rules, I'll be headed home early..... http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif Ok cleared up Have you ever had your woofers blown?
sactownstang Posted March 28, 2009 Report Posted March 28, 2009 Let's make it clear in street classes u must have a battery in the stock location. In street C you are allowed 2 batteries, however still one must be in stock location. Battery box is not permitted in Street classes, SS NW, Street Max Street Stock: Standard 650 in^3 x 1 12 volt Car may be started during run. Street A: Standard 650 in^3 x 1 12 volt Car man NOT be started during run. Street B: Standard 800 in^3 x 1 12 volt Car may NOT be started during run. Street C: Standard 800 in^3 x 2 12 volt Car may NOT be started during run. Street Max: 1 battery Car may NOT be started during run SS NW: No Limit 18V Car may be started during run. SS 1-2: No Limit 18V Car may be started during run. SS 3-4: No Limit 18V Car may be started during run. SS 5+: No Limit 18V Car may be started during run. EXTREME: NO LIMITS
FreelandKustomz Posted March 28, 2009 Author Report Posted March 28, 2009 Thanks for posting that sactown!
sactownstang Posted March 28, 2009 Report Posted March 28, 2009 plz check again I updated it...all rules quoted from db drag web site. Final post was at 1:34 PM
