i no but they still look really choppy.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
yaa those lok really bad, test fit teh subs, and make sure you can crew them down wihout missing, also may i sugest putting sme foam strips down so youcan keep the subs from leaking air also make sure you screw the subs in th correct so that you don't bind the frame
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Hey you guys could i put a chamber in this box? would it mess up anything?
BANNED LIKE A MOTHAFUCKA
IM BANNED BECAUSE IM A FUCKIN FUCKTARD
what do youmean by chamber?
like to piece of wood in the middle to make almost like 2 boxes.The guy who designed it said it would make the tunning off.So i was just wondring.And about the hole i am going to sand in perfectly.I was going to use bolts but i couldnt find the nut size.
Looks good man! i think that you should double baffle it! keep the pics comming in!
you get an A for effort with me bro.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
thanks man. Its my third build but i consider this my first box because this is the only one wher its tunned to something and built the right way.
well i teh guy said it wi be off, i will be off
use thread rod for bracing, or a 2x4
