Colin - STAPUFT Posted April 11, 2015 Author Report Posted April 11, 2015 New pictures: Rear fill on L&R is gone: Big ported box for single MTX 5000 8": I have leg room again!!! And so does the passenger's seat! Snug as a bug in a rug: See where the keys are in the middle? That's where I'm putting a single 4" (same as the ones up front) as rear fill. Aaaaand done with front soundstage work for a while. lol I will eventually re-do the door pods that house 8"s- to make them look better and a bit more solid. But no rush on that. ...like at all. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back.
ShadeTreeMechanic Posted May 4, 2017 Report Posted May 4, 2017 Just read through this. Thinking about a clamshell for 6 12s. Does anyone know if OP is still around? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
