2 Ap 30001ds For Sale Price Lowered!
FOR SALE:
Two Audiopipe AP30001D monoblock amplifers. One amp is BNIB and the other has been in the truck for about 5 days.
Each amp is over 30 inches long and is rated for:
600 Watts RMS x2 at 4 Ohms (<1% DISTORTION)
950 Watts RMS x2 at 2 Ohms(<1% DISTORTION)
1,500 Watts RMS x2 at 1 Ohm(<1% DISTORTION)
3,000 Watts RMS x1 at 2 Ohms(<1%DISTORTION)
Input Level: .2-5V
Freq. Response 8-180hz
LPF 40-180hz
SUBSONIC Filter 5-50hz
Bass Boost Frequency 30-80hz
Bass Boost Level 0-12db
THD at 4 Ohm load 30% Rated Power <.2%
S/N Ratio >70db
Efficiency: >85%
Minimum Load 2x1 Ohm or 1x2 Ohm
Optional Remote
Brigeable with Same Amp
Overload Protection
Short Circuit Protection
Overheat Protection
Each amp comes with an Audiopipe Remote Bass Module, a 200 amp ANL fuse and Fuse block, Manual, and Accessories.
Pics:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Price $790 plus shipping for BOTH AMPS!!! If you can drive to Columbia, SC, then save your shipping and come get 2 monster amps.
Also, I can do 8 months warranty on these if sold before April 7th.
what would they put out at 1 ohm off of each? jus 1500 watts rms?
Jensen 9511TS~For Sale
JL Audio 300/4~For Sale
JL Audio1000/1~For Sale
Mephis 6.5 componet sets front and rear
4 15" Fi Q's in a 16 cuft box tuned to 29hrz
The amp has 2 channels, each 1 ohm stable. At 1 Ohm, each amp puts out 1,500 watts RMS to each channel. It is bridgeable, just like any other 2 channel. Then, the amp is stable to 2 ohms and puts out 3,000 watts RMS @ 2 Ohms.
Inside, it looks like two separate amps in one looong (30 inch) heatsink. Heres a pic of the board, which looks a lot like the Massive 3000D.
Posted Image.
These amps make 3,000 REAL RMS watts each. Together they are both fused at 400 amps.
so what your saying if linked together each amp puts out 3000 watts rms per amp?
no its 2 1500 watt amps combined to make 3000 watts at 2 ohms
there internally bridged 1500 watt amps making 1 3000 watt amp
he is selling 2 3000 watt amps
R.I.P!
(Nov-29-2009)
92 explorer
current build
