looks like its in good condition for 800$ thats a steal
R.I.P!
(Nov-29-2009)
92 explorer
current build
It won't be an all out spl monster like a lot of them I see. I will be driving it quite a bit. with the upgrades I just did in subs and doubling my amps I hope to get about 145-146 term-lab out of it. Good enough for the local comps. I'm going to have to do some electrical upgrades first. H.O alternator first thing after I transfer my 0/1 gauge over from my other car. Then big 3.
what is your plans for subs and amps? 146 is VERY LOW for a crx.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Well, I probably am being Conservative. Just for right now I am going to run 2 3xl powerbass 12's with a 1000.1 powerbass on each sub at a 1/2 ohm in a custom box tuned high. I had a run of bad luck on amps so last months comp I used my old kenwood 850 watt and did 147. It was an audiocontrol meter though.
That was in a ford contour as well.
Edited by alvitae
if you did 147 in the contour there is no way at all possible once so ever it will be lower than that.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
yea it will score pretty well. when will you have #'s
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
If my amp gets back I will buy the second one and will have a run in on the 17th. It will be with out the alternator though and just the underhood battery and 2 kinetik 1800's. I probably won't have an alternator that early.
yea is the 146 your hoping for on music or a tone?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
I use tones. I have a tone cd and a tone generator. With my other car I know songs that hit just about as hard as a tone but it will take a while to figure this car out.
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
