First off wanted to thank everyone here! I've learned so much from you guys, been following the site for the last year and a half and finally posting. On to my question....
What do you guys think of this
One thing I already noticed is, I should change is put my "-" wire on the buss bar, closer to the starter battery.
once the alts are paired with a (+) wire you you only need one run to battery (+)
also, front bat can use a single ground and i would ground the rear bank in the back as well as the full run.
sketch looks good though- the way you have it now would work fine
-Drew
**if starter bat is in the trunk two runs of (+) to back would help a ton, why not bus bar all the bats if they're all in the trunk?
Edited by Noobtastic14
uhoh_45 said:
I thought about doing that also, bussing all the batts, but the starter sits alittle further up front than where the other 4 would go.
Edited by OBI
How much power are you looking to have?
with the starter bat and bat bank so close- they may not need fuses between them.
it if was a front/back run then yes you would need it
-Drew
I think more than 1 run to the back batteries be needed, because 2- 360 amp alts and 1 run of maybe 18- 20ft of 0/1g to the back? I would do atleast 2 runs
yeah-
i would do multiple runs from alts to bats in the back (where i'm assuming your start bat is)
the more the better really, and everything grounded in the back to FRAME and maybe a run or two to the front if your feeling it.
-Drew
So I should do 3 "+" runs of 0/1 off 1 alt?
yeah- i thought you had a bat under the hood
which means you only need one run of 1/0 to the bat (because its pretty short) and do multiple runs of wire to the back because its a longer run. Now that i know all your bats are in the back your going to need to put run one of wire from alts to some sort of distro where you can run multiple runs to the bank in the back
-Drew
Another thing that I thought of doing for the batts was to add a second bar (at a angle) connecting the starter to the first(closest) aux batt.
  • Who's Online   0 Members, 0 Anonymous, 822 Guests (See full list)
