Can I Wire My Amp Like This
dynodan9
I have a set of Infinity Kappa's 6.5 coaxs that are 2 ohm. But I had planned on getting another set of MB quarts that are components that are 4 ohm. Can you run a set of 2 ohm speakers and another set of 4 ohm speakers off of one 4 channel amp with no negative side effects?
nope, you will be fine
Eclipse cd7000
you'll be fine
just hook up speakers to terminals like you normally would, the 2ohm kappas will get more power though, so you may have to fade forward or backwards to even out the sound.
Team DC
