Making A Component Set, Got A Quick ?
siucsaluki11
So im looking at building a component set for my front doors with items from parts-express. Im having a bit of an issue when it comes to matching the components based on impedance. If i do this i will either make my crossovers (i like tinkering with shit) or just buy some pre-built ones. So...the speaker wire runs from the amp to the crossover then signal runs from the crossover network to the drivers (im looking to keep it at a 2-way for now so to the woofer and tweeter). If the woofer and tweeter are both 4 ohm speakers, what will my final load be for that channel? Im a bit confused, would it stay at 4 or drop to 2. Im guessing it wont rise to 8, but ya, just a bit confused. Do i need to get 8 ohm drivers to give me 4 ohms? Any and all help appreciated.
Thanks
i just read my towers, which use 2-way passive crossovers. the final load from the speaker terminals (where you hook up the amplifier to) is 4 ohms, and the tweeter and midbass each read 4 ohms also.
so i guess if you want a 4 ohm final load, get 4 ohm midbass and tweeters
I have a set of phoenix gold rsd's. the tweeter is marked 4 ohms, and so is the woofer. and the set with the crossover (passive) is at a final 4 ohm impedance.
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
thanks for the help guys
  • Who's Online   0 Members, 0 Anonymous, 1064 Guests (See full list)
