Guest MegaloManiac
yea. i guess its the same thing. but i just merely implying that get a worthy alarm system, not just some "alarm"
well an alarm usually just beeps. a security system usually does alot more
the one im looking at does...
Up to 3000* feet of Range
This model was introduced in 2004 as one of the first 900 MHz systems on the marked. It has the largest LCD of any CompuStar remotes along with a built in clock that also displays remote start run time. The 900MHz technology supports a longer battery life and a quicker response time between the transmitter and receiver. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications. The 2W900FMR is available as a 2nd Car controller (blue casing) or a Turbo Timer controller (white casing)
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
Remote Features
- Two-way paging remote
- Vibrate and audible notification
- Run-time indicator
- Detailed icons
- Turbo timer or 2nd Car
- CompuGlow backlight
- Multi-color LCD (liquid crystal display)
- RPS on/off through remote
- Shock sensor on/off through remote
- Passive on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
- Built in Clock
- Largest LCD of any CompuStar remotes
- 2004 CES Innovation Award Winner
View the manual for the 2W900FMR
This is available in English and French
Alarm Features Starter Features Alarm/Start Features
- Includes dual stage shock sensor
- RPS (remote paging system)
- External Siren (six-tone)
- Super bright blue LED's
- 2-auxillary outputs, expandable to 7 with Channel Expander
- Dedicated trunk release output
- Horn honk output during alarm
- Includes starter-kill relay
- Driver's priority unlock
- Ignition controlled door locks - Factory style alarm
- Dedicated trunk output
- Horn honk output
- Timer start every 1.5 or 3 hours
- Cold start with optional Temperature Sensor
- Includes anti-grind/starter-kill relay
- Manual transmission compatible - Includes dual stage shock sensor
- Includes anti-grind and starter-kill relay
- Trunk release output
- Diesel features built-in
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
