OrenB217 Posted April 11, 2009 Report Posted April 11, 2009 Will the Hifonics BXi2608D 1-Channel Amp be good enough to power 2 15" Kicker L7 (2 ohm each)? I think I want to start out with this amp before I upgrade to fosgate or sundown, so any suggestions would be great. Black 1998 Nissan Maxima1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk2nd Setup: 147.8 DB @42 HZ On Music Out The TrunkCurrent Trunk Build:153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)Team gg.
cesarbernal Posted May 8, 2009 Report Posted May 8, 2009 Will the Hifonics BXi2608D 1-Channel Amp be good enough to power 2 15" Kicker L7 (2 ohm each)? I think I want to start out with this amp before I upgrade to fosgate or sundown, so any suggestions would be great. i just ordered the 2610 i get back to u when i hook it up
Bunker Posted May 8, 2009 Report Posted May 8, 2009 Yes it will push them fine J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Remarkable Flex Posted May 8, 2009 Report Posted May 8, 2009 you'd be fine with a 2010D also, giving 1000w RMS for each sub if you're on a budget.
07sOnAtA sp.ed Posted May 8, 2009 Report Posted May 8, 2009 Yes it will push them fine this. CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
a_steezy Posted May 8, 2009 Report Posted May 8, 2009 i dont think it will push them good. if the subs are 2ohm as you said you have to wire the subs down to 2 ohms into the amp. that amp claims "1700" watts at 2 ohms and it's over rated, probably more around 1500 watts now if your subs are 4ohm youre golden. '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex
