How To Know If A Subwoofer Is Damaged?
I was running a 30 second, 50 hz tone earlier today and all of a sudden the sound on my 10 inch amp kinda died out (not suddenly, but you know what I mean). Would this have hurt the woofer, or was it the amp's problem? Also, is there any finite way to know if a woofer is actually damaged? Thanks.
take it out and look at it. Push the cone in the center and see if there is any noise it shouldnt be making.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
you should check the amp connections and connections to the sub first. then check voltage, how much power and what sub were you running ?
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Ouch man, hopefully everything is all good.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
easiest way is to put a C cell battery or whatever size you have on the speaker wire.
+ of battery to + speaker wire and - to -
granted all your connections are good the speaker should move. if it doesn't then its fucked
  • Who's Online   1 Member, 0 Anonymous, 575 Guests (See full list)
