solo z Posted April 14, 2009 Report Posted April 14, 2009 http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3652 yea yea i kno its prefab but my guy need to start somewhere! i may mock it and take a shot at making a real one for him once he gets the ball rolling but for right now im curious. subs are 3 cvx kickers
uhoh_45 Posted April 14, 2009 Report Posted April 14, 2009 30hz but either that picture is not the right one or there specs arnt right cause that doesnt look like a 25.5" long port R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
morales209 Posted April 14, 2009 Report Posted April 14, 2009 30hzbut either that picture is not the right one or there specs arnt right cause that doesnt look like a 25.5" long port ports look small
solo z Posted April 14, 2009 Author Report Posted April 14, 2009 30hzbut either that picture is not the right one or there specs arnt right cause that doesnt look like a 25.5" long port really? i guess thats why we have to start making our own crap...i dnt even have a sawzall though! lol should he not waste the money? if the port is smaller then its probably tuned a good bit higher right?
uhoh_45 Posted April 14, 2009 Report Posted April 14, 2009 25.5" port would look like this and for the 230$ you'd spend on this you could make like 5 of your own box's and why would you need a sawzall ? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
E-Train Posted April 14, 2009 Report Posted April 14, 2009 for 230 bucks you can build your own box and it would be alot nicer, hell i built my box for 2 15's for under 150 bucks. Thats with the cost of buying a router, that covered, wood, glue, bracing, router n router bits. 1997 4 Runner Alpine CDA-9886 4 Fi Audio X Series 12's 1 Crunch GP3000D Pro DC Power Inc. Alternator(Kickin out 15+ volts!)
solo z Posted April 15, 2009 Author Report Posted April 15, 2009 25.5" port would look like this and for the 230$ you'd spend on this you could make like 5 of your own box's and why would you need a sawzall ? thanks for the idea! do u hve the actual lenth of cuts on this box? maybe we could get started...what i meant by not havin a sawzal is that i dont own one piece of cutting equipment and sawzals are the most common house hold cutter. well im going to try making boxes myself.....besides cut lenths what type of cutter should i buy? nothing top of the line but somethin that can provide smooth edges and circular cut-outs and so forth??
Torres Posted April 15, 2009 Report Posted April 15, 2009 buy a drill and jig saw and you can build yourself a box. might not be the most beautiful box ever (you could cover it with carpet to help that ) cut the sides, drill holes and screw and glue the joints. even you wanted to get REALLY frisky you could buy a sander and tidy up the edges EDIT: lol the only time i'd ever use a saws-all on a box would be to tear one out lol. they cut through mdf like butter
solo z Posted April 15, 2009 Author Report Posted April 15, 2009 lol thanks for the heads up guys! anyone know a good DIY thread for begginers? i have a drill so thats covered...i would have to look it the jigsaw though! and maybe even a stable for straight cuts??? alot of people on here seem to not use screws but i dnt see how im not supposed to use them specially in begining stages. what do people use to hold the box together while the glue dries even they dont use screws?
